ianm67
posted on 14/2/14 at 03:33 PM |
Starter motor choices?
Hello chaps,
I have been doing a bit of research on this and other forums and I am a little confused....... I have a blacktop zetec and a T9 g'box going
into a Dax Rush shortly. The engine has been fitted with a 1.8 zetec flywheel and Mondeo 1.8 clutch plate and cover. Standard T9 cast bellhousing and
clutch arm and CT133 thrust bearing.
I have seen two starter motors used: LRS543 and LRS707. Which one do I use......??
Thanks in advance,
IanM
Always biting off more than I can chew.....
big_wasa
posted on 14/2/14 at 04:56 PM |
What ever you can get to fit, there is more than one that will do the job and you can find two of the same model number where one may fit and not the
other if made buy different company's.
