cerbera
posted on 20/2/14 at 06:29 PM |
Help wiring a central heating thermostat.
Just need a little reassurance from the collective that what I'm thinking is right before I wire up a new thermostat.
Boiler Wiring Diagram
Terminal 1 of the boiler goes to terminal 1 of the thermostat.
Terminal 2 of the boiler goes to terminal 4 of the thermostat.
Thermostat Wiring Diagram
Thanks in advance.
[Edited on 20/2/14 by cerbera]
Wadders
posted on 20/2/14 at 06:48 PM |
Depends on the make of stat, on Honywell stats its normally terminals 1 & 3.
Just check continuity on terminals and turn stat up and down if unsure which are switching.
Al
serieslandy
posted on 20/2/14 at 07:32 PM |
If your new room stat is an 'owl' one as per the paperwork.
Then yes your correct.
cerbera
posted on 21/2/14 at 07:05 PM |
