TrophyJem
posted on 27/2/14 at 09:45 AM |
Brake hose fitting thread to Ford clutch slave
Does anybody know what thread the fittings are on a Ford clutch slave cylinder?
I want to get some hoses made.
russbost
posted on 27/2/14 at 10:01 AM |
Any modern car will be m10 x 1.0 with very few exceptions
TrophyJem
posted on 27/2/14 at 02:28 PM |
Thanks.
They can't both be 10mm though as one is smaller than the other
[Edited on 27/2/14 by TrophyJem]
russbost
posted on 27/2/14 at 02:58 PM |
Sorry, you mentioned hoses, only one is a hose fitting, the m10 x 1.0 one the other is for a bleed nipple & is either m7 or m8, can't tell
from the pic as they are very similar though I think it's m8, if you're looking to take a hose off from the smaller one to bleed outside
the bellhousing if it's m8 you can do it with a m8 banjo fitting, but you'll need to find a suitable bolt. Our m8 banjo bolts are m10 x
1.0 (fit pitbikes etc.) the bleed nipple thread if it's m8 will be m8 x 1.25, banjo bolts are available in that size. If it's m7 then
it's time for a rethink or some drilling/retapping!
TrophyJem
posted on 27/2/14 at 09:23 PM |
Cheers for the info.
Most helpful.
