Niels
posted on 4/3/14 at 03:46 PM |
Engine placement MK Indy ZZR1400
I'll first give a short introduction to myself as I couldn't really find a specific topic for this on the forum. I'm Niels, 24 years
old living in Belgium. As from last october I've started building an MK indy together with my dad! Not a new one due to legal limitations but
we've bought a second hand mk indy which we stripped down completely. As we are going to put another engine (zzr1400) in the car we would like
to get some advise from the pros around here.
Is there any theoretical information about the placement of the engine? If I understand it correct, most preferably the output from the engine should
be aligned with the input of the diff. Though, when I look around on the forum and photos from other bec's, neither of them seems to apply to
this from what I can see from the photos. Maybe there is someone on the forum who has already placed this engine in his/her mk indy and can supply me
with some more info.
Many thanks in advance!
Niels
skippad
posted on 4/3/14 at 05:06 PM |
hello Neils
Welcome to the forum
If you look in my photo archive "zzr engine" there is pics of of my ZZR1400 install.
Any questions feel free to ask
Dave
snapper
posted on 4/3/14 at 05:32 PM |
I eat to survive
I drink to forget
daniel mason
posted on 4/3/14 at 06:20 PM |
all mk's ive seen have the engine in line with the top chassis rail,meaning they are not even close to sqare.
ReMan
posted on 4/3/14 at 07:42 PM |
But most have a centre bearing, though why that should make a difference I don't know.
All I know is that as that was my original (MK) set up I had no problems; I fit a reverse box with 2 props and half the angles and I get vibration!
But that's my bad, not a Hijack!
I assume as per the 4th diagram above, the point is "excessive", unequal angles, minimal unequal angels should not cause a problem
www.plusnine.co.uk
twybrow
I was told by Dunning and Fairbank (propshaft supplier) that the maximum misalignment between prop, engine and diff, is no more than 7 degrees. When I
bought my cat part built, it had the engine paralell to the top chassis rail, which meant far too much misalignment... So I rebuilt the engine cradle
and exhaust to allow the engine to sit closer to square.
snapper
posted on 4/3/14 at 08:57 PM |
So on a BEC instal the diff to reverse box can be set within tolerance the engine placed to provide correct angles for engine to front of reverse
box
I know Bailey Morris have experience with props for BEC instals and a lot of people have more acute angles than the recomended 7 degrees for the
engine output
I eat to survive
I drink to forget
Niels
posted on 5/3/14 at 01:35 PM |
quote: Originally posted by skippad
hello Neils
Dave
Did you just fit the engine trial and error trying to get an appropriate alignment? Is there any chance that you still have some measurements from
back then?
quote: Originally posted by snapper
[img]http://s750.photobucket.com/user/snapperpaul/media/69889BBA-5D98-4428-810B-A4B2AA9B38F7.jpg.html[/img]
So a dead straight alignment isn't the best solution? Is this for the sake of lubrication and wearing?
Is this misalignment of maximum 7 degrees applicable for both the horizontal and vertical plain?
Does weight distribution play a major role as well, probably it does but the amount of freedom is maybe limited? Therewith we're building a LHD
so the steering rack needs to fit as well.
Niels
twybrow
posted on 5/3/14 at 02:45 PM |
hello Neils
Dave
back then?
The 7 degrees applies to both planes (horizontal and vertical). They actually said aim for 2-3 degrees if you can (avoiding being perfectly
straight).
@snapper - just because you see a lot like that, does not mean it is correct! I wanted to do everything I could to avoid propshaft issues, as is is so
safety critical.
[Edited on 5/3/14 by twybrow]
jacko
posted on 5/3/14 at 03:31 PM |
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=08042007067.jpg
This photo is off a zx9r fitted in a mk indy chassis if this helps
Niels
posted on 5/3/14 at 03:57 PM |
Thanks for the pics and explanations.
Bike engines are mounted without any rubbers am I correct?
peter bland
posted on 5/3/14 at 04:32 PM |
When mounting it's always safer using rubbers , but more pleasure without. Oooooops different subject.
Bike engines solid mount.
