Author: Subject: Blacktop changes 02/99
obfripper
posted on 17/3/14 at 09:47 PM Reply With Quote
Does anyone know why early mondeo/focus 2.0 zetecs have a 1.2mm headgasket, and later ones 0.6mm?
I haven't stripped my early engine yet, but i have a late (2004) new bottom end, and am not sure which headgasket will be correct.
My head is the magnesium cover type, and the pistons appear similar down the plug hole.
I don't fancy ending up with an excessive comp ratio from mismatching head/gasket/block.
Thanks for any info,
Dave
posted on 18/3/14 at 07:38 AM Reply With Quote
Why are you stripping the engine? If the engine is suspect it's probably far cheaper to replace than rebuild
Paul Turner
posted on 18/3/14 at 01:40 PM Reply With Quote
The material the gasket was made from was totally different, guess it was just one of Fords updates, never heard of a problem. Mix and match components and you could possibly end up with a small compression ratio increase but you should have no issues with valve/piston contact unless you use a really hot cam.
Only way to tell for certain is to do a dummy build and check the volumes.
There are several other minor differences between the very early Blacktops and later ones, none make any difference to fitting the engine in a kit. Off the top of my head the later ones have fewer core plugs, a different hole machined in the head for the temp sender (instead of in the stat housing) and the early ones had 2 idler pulleys on the cam belt, the later ones had only one.
