Author: Subject: Smoking 1300 x flow
Monty2556
posted on 18/3/14 at 05:38 PM Reply With Quote
Smoking 1300 x flow
I've got a 1300 x flow which is due to be replaced with a 1600. I'd like to be able to sell the 1300 engine but it seems to be running very poorly. It's totally gutless (even for a 1300), uses a lot of petrol and smokes from the oil filler on the rocker box. Any ideas?
Jon Ison
posted on 18/3/14 at 05:48 PM Reply With Quote
Sell it running but requiring rebuild, sounds tired rings, bores probably valve seats & guides too.
Nickp
posted on 18/3/14 at 06:46 PM Reply With Quote
Check the breather isn't blocked maybe?
Monty2556
posted on 18/3/14 at 11:39 PM Reply With Quote
Thanks I'll try the breather first and then take it to bits. I doubt I'd get much for a 1300 cross flow.
Nickp
posted on 19/3/14 at 03:50 AM Reply With Quote
Do a compression test before you pull it apart, but tbh it does sound pretty goosed
snapper
posted on 19/3/14 at 07:00 AM Reply With Quote
1300 pistons fit 1600 engines and give more compression
Whip out the pistons, keep them for your 1600 and flog the other bits
[Edited on 19/3/14 by snapper]
I eat to survive
I drink to forget
Monty2556
posted on 19/3/14 at 08:09 AM Reply With Quote
Good idea. The 1600 I have is a 691 block. Will the 1300 pistons still fit. Is it just a case of getting appropriate rings and popping them in?
Trollyjack
posted on 19/3/14 at 08:36 AM Reply With Quote
u2u sent
TrollyJack
posted on 19/3/14 at 09:38 AM Reply With Quote
Depends on if they are both on the same rebore size.
Monty2556
posted on 19/3/14 at 11:18 AM Reply With Quote
Off topic slightly, is there that much difference between a 711 block and a 691 block given that i don't want to increase the capacity nor do i want an engine that revs to 10000! Just a mild tune.
Marcus
posted on 19/3/14 at 06:10 PM Reply With Quote
In a 681 the crank journals are narrower and the cam followers are thinner. This wouldn't be an issue for a mild tune
Marcus
Because kits are for girls!!
Monty2556
posted on 19/3/14 at 07:33 PM Reply With Quote
It's actually a 691 block and from what I can gather the bottom end is the same as a 711 but the rest is as per the 681 block.
By the way, what does "u2u" mean? Am I being a numpty?
posted on 19/3/14 at 07:48 PM Reply With Quote
Click on u2u just under the L of Locostbuilders at the top left hand corner of most pages of the forum , it's an internal email system . I'm a complete numpty when it comes to PCs but even I worked it out
