Author: Subject: Shortening a 1600 xflow oil pickup pipe
Kaino
posted on 25/3/14 at 03:35 PM Reply With Quote
Hi guys,
Can anyone give me some good advice on how to succesfully take 40mm from the original 1600cc xflow pickup pipe? (The type with the deeper mesh on the strainer, not the flat pancake type)
Have people heated then tried to bend the pipe to sit lower? Can you chop the pipe behind the gorse part then tack weld the strainer back in place?
Any help greatly recieved please.
Kaino
19sac65
posted on 25/3/14 at 07:19 PM Reply With Quote
on zetecs they tend to cut it then sleeve it and get it brazed or soldered
dont wasnt it dropping off !!
macc man
posted on 25/3/14 at 07:51 PM Reply With Quote
On my Zetec I got a guy to tig weld it after chopping it. Seems to work fine.
The Black Flash
posted on 26/3/14 at 10:55 PM Reply With Quote
Not the same engine, but I had my sump shortened and the guy chopped and rewelded the pickup.
posted on 27/3/14 at 12:40 PM Reply With Quote
I used soft solder to fix a metal sleeve over the join after shortening - I can't remember if I used brass or steel for the sleeve - it's not going to get hot enough to melt. At least, if it does get hot enough then i'd have other things to worry about!
loggyboy
posted on 27/3/14 at 12:58 PM Reply With Quote
Again its zetec, but I just mig'd mine.
More pics.
http://www.loggyboy.com/images/Raw/Sump
[Edited on 27-3-14 by loggyboy]
Mistral Motorsport
