Monty2556
posted on 27/3/14 at 03:07 PM |
Weber carb throttle assembly
I've got a 1600 crossflow which came with an inlet manifold to take a twin choke Weber. The manifold doesn't have the two bolt holes into
which I would attach the throttle cable assembly. How do I attach the throttle cable to the carb?
r1_pete
posted on 27/3/14 at 06:50 PM |
I've seen the outer cable stop on the rocker cover on some Mk1 Escort installations, a better, more elegant solution would be a sandwich plate
between the carb and manifold, with an appropriate extension for the cable stop,
redturner
posted on 1/4/14 at 07:20 AM |
You need a 711m manifold. I have several if interested...........
Monty2556
posted on 1/4/14 at 04:42 PM |
How much would you want for one of the 711 manifolds. I assume it's the manifold with two bolt holes.
Many thanks
