Author: Subject: xflow/type 9 clutch?
benchmark51
posted on 2/4/14 at 07:27 PM Reply With Quote
Using a 711 xflow 1300 engine and a type9 gearbox.
Flywheel takes a 190mm clutch assembly, so which clutch will I
need for the 23 spline first motion shaft of the type 9?
I have a 215mm flywheel and clutch, but the flywheel hasn't got
the recess for the crankshaft.
19sac65
posted on 3/4/14 at 03:36 AM Reply With Quote
Check out the spec on a cortina capri 2.0 4 spd drive plate
I know its 23 spline and its def smaller than 215mm
owelly
posted on 3/4/14 at 04:08 AM Reply With Quote
Have a looksy here:
http://www.national-auto.co.uk/assets/content/documents/clutch_cat_24.01.14.pdf
A quick peek suggests that a CK 9564 would give youa 190mm plate with a 23 spline centre.
http://www.ppcmag.co.uk
benchmark51
posted on 3/4/14 at 06:43 AM Reply With Quote
Thanks lads, much appreciated
