Author: Subject: zetec
bigwill64
posted on 13/4/14 at 04:30 PM Reply With Quote
zetec
can anyone advise on what management(cheap options ) is best and easiest to use on a zetec.also what carbs need the least work to fit .thxs in advance.
avagolen
posted on 13/4/14 at 05:10 PM Reply With Quote
Hi, I have used a megajolt with an ignition map from another LCB member and ZX6R carbs on my pre 95 silvertop.
So far I have had to spend nothing extra and the engine runs and revs nicely - after a deep clean with carb cleaner
and balancing with a suitable airflow meter.
Just got to get it on a rolling road for final setup / emission's check.
Standard jets in my carbs are 0.6 which is where most people say to start.
Len.
pekwah1
posted on 13/4/14 at 05:41 PM Reply With Quote
Cheapest has surely gotta be standard ECU and ignition?
Plenty of us have done this now with good results!
bigwill64
posted on 13/4/14 at 06:59 PM Reply With Quote
zetec
i dont want to use standard ecu as i want to fit cams, exhaust, etc as time goes by and funds allow.are maps readily available for megajolt?
avagolen
posted on 13/4/14 at 08:27 PM Reply With Quote
Basic working maps for a reliable starting point -yes.
Once you start modifying you are on your own. :-)
