James
posted on 21/4/14 at 11:17 PM |
How many splines on Type 9 shaft
I want to order a new clutch for my Pinto with Type 9.
Parts place want to know how many splines on the shaft.
Anyone know, before I have to have the thing half apart? (I want to do the work at my mate's garage but will have to drive it there).
It's a standard Type 9 from a 2.0 injection Pinto engined saloon sierra.
I think the choices were 25 or 19 (I can't remember exactly) splines!
Thanks!
James
- Muhammad Ali
19sac65
posted on 22/4/14 at 03:38 AM |
23
If my memory's correct,19 splines were for 1.6 4 spd cortina and mk1 sierra
benchmark51
posted on 22/4/14 at 06:53 AM |
Just done one and it had 23 splines.
owelly
23 splines on a nominal 1" (25.4mm) shaft.
http://www.ppcmag.co.uk
Paul Turner
posted on 22/4/14 at 08:05 AM |
The spline count was 20 on the light duty 4 speed boxes and the shaft was only 7/8" diameter.
As other have said its 23 splines on the type 9, 1" diameter.
mcerd1
posted on 22/4/14 at 09:37 AM |
this is the clutch you want for a 2.0 pinto
LUK made - OE spec. - as used by lots of stock car engines
http://www.burtonpower.com/parts-by-fitment-type/parts-by-engine-ford/ford-sohc-pinto/luk-std-clutch-kit-2-0-sohc-pinto-215mm-622017506.html
as above type 9's along with MT75's, borg warner T5 & types 5, E & F all have a 1" shaft with 23 splines
the rest of the RWD boxes (2000E & type 2 & 3 ) have 7/8" shafts with 20 splines
there is a good little guide to each box here:
http://www.burtonpower.com/tuning-guides.html
[Edited on 22/4/2014 by mcerd1]
James
posted on 22/4/14 at 03:07 PM |
Thanks all!
James
- Muhammad Ali
