Author: Subject: Zetec / Type 9 clutch
Plunky
posted on 23/4/14 at 12:36 PM Reply With Quote
Hi Guys,
I know there is loads of info on the web about clutches for zetec / type 9 conversions... however I am asking for something a bit specialised.
I am currently changing my silvertop for a blacktop and thought I had better change the clutch while it is all out.
the clutch has the following numbers on it...
LUK - 284 04 / 237 10
Any ideas what clutch it is?
Liam
owelly
posted on 23/4/14 at 04:31 PM Reply With Quote
Give these guys a ring:
http://www.clutch-specialists.co.uk/
Tell them the I/PPC Magazine gave you their details. ;-)
http://www.ppcmag.co.uk
mcerd1
posted on 24/4/14 at 07:55 AM Reply With Quote
sorry can't tell you what the number means
but if you can measure the size of it that'll help narrow down the possibilities
Plunky
posted on 27/4/14 at 10:50 AM Reply With Quote
Clutch diameter is 217mm
posted on 27/4/14 at 10:53 AM Reply With Quote
What flywheel is it? 2.0 or 1.8?
Plunky
posted on 27/4/14 at 11:08 AM Reply With Quote
I'm assuming 2.0, could be wrong though, is there an easy way to tell?
posted on 27/4/14 at 04:25 PM Reply With Quote
This is a 1.8, does it look like this?
Or, does the clutch sit 'inside' as the 2L job has a raised section round the edge.
Paul Turner
posted on 27/4/14 at 05:44 PM Reply With Quote
And here is a 2 litre one.
[img]
[/img]
Plunky
posted on 27/4/14 at 06:43 PM Reply With Quote
I think it is the 1.8 one from memory
posted on 27/4/14 at 07:34 PM Reply With Quote
A Mk1 Mondeo clutch fits the 1.8 no problem.
Plunky
posted on 27/4/14 at 10:08 PM Reply With Quote
http://bit.ly/1nxPKw9
Like this one?
Paul Turner
posted on 28/4/14 at 09:09 AM Reply With Quote
Like this one?
That will not fit a 1.8 flywheel. The photo's on the 2 posts above clearly show the difference and the clutches are not interchangeable.
The clutch in your link is for a FORD MONDEO MK1 MK2 2.0 1993 TO 1998 , spot the 2.0 in the listing title.
This is probably what you need for a 1.8 flywheel (from the same site).
FORD MONDEO MK1 1.6 1.8 CLUTCH KIT NEW
[Edited on 28/4/14 by Paul Turner]
