Author: Subject: twin throttle support brackets
cfc999
posted on 30/4/14 at 09:01 AM Reply With Quote
Does anyone make a off the shelf bracket to support twin throttle cables for my xflow striker running twin 40's. I've seen a pic of some that bolt onto the top of each carb corner clamping each cable making things nice and neat.
Ot is it a matter of fabricating a couple of brackets.
Chris.
[Edited on 30/4/14 by cfc999]
theduck
posted on 30/4/14 at 11:53 AM Reply With Quote
Mangoletsi make some nice twin cable dcoe linkages.
posted on 30/4/14 at 12:01 PM Reply With Quote
Twin cable linkages not a good idea, they cause more friction and are likely to cause major damage to the carbs.
A single cable that is correctly adjusted to open the throttles 98 to 99% is the most reliable and effective way to go.
cfc999
posted on 30/4/14 at 12:28 PM Reply With Quote
My twin 40's xflow powered Striker is up and running and all I'm after are some info regardind throttle cable support brackets.
My linkage is all set up and working as it should.
I just want to finish the engine bay off with some nice brackets that offer some support for my throttle cables from my pedal box to my twin carb linkage.
