Author: Subject: Clio expansion tank inlet sizes
OliilO
posted on 18/5/14 at 07:44 PM Reply With Quote
Evening all,
Slightly random but does anyone know what the inlet sizes are for a Clio mk2 expansion tank?
I'm replumbing my cooling system and it seems that these are a common choice, so am trying to check all the hose sizes before ordering.
Also, can anyone confirm if a polo radiator bleed take off is 8mm?
Thanks.
renetom
posted on 19/5/14 at 08:09 AM Reply With Quote
Hi
Got ours from breakers, about £2
If I remember rightly the bottom is 13mm top is smaller
we had to adapt up as our top pipe was 8mm.
Clio correct cap
Clio correct cap
we cut off our bleed tube from our polo rad as did not need it
on our BEC
Waterworks R1 Indy
Waterworks R1 Indy
good luck
