Author: Subject: Zetec Block Width
Ugg10
posted on 21/5/14 at 08:06 AM Reply With Quote
Zetec Block Width
I've done a search but could not come up with an answer, so -
Can anyone tell me/measure the width of a Zetec (silver/black top) across the mounting points typically used for RWD applications.
Thanks in advance
[Edited on 21/5/14 by Ugg10]
loggyboy
posted on 21/5/14 at 10:11 AM Reply With Quote
Mounting points will very from car to car and install to install.
The acctual block is about 240mm going buy this: (200mm for sump width plus a little)
http://omextechnology.co.uk/Omex%20Zetec%20Focus%20Engine%20v1_31.pdf
[Edited on 21-5-14 by loggyboy]
Mistral Motorsport
Ugg10
posted on 21/5/14 at 06:28 PM Reply With Quote
Loggyboy, many thanks for the info. Just to confirm it is the block width that I want.
The reason for this is I am fitting a 1.7 puma engine to an anglia with an escort cross member and I am trying to work out if itis easier to mod a set of zetec/pinto/xflow mounts than get some made up from scratch.
Any more info on the various block widths would be gratefully recieved.
loggyboy
posted on 21/5/14 at 07:14 PM Reply With Quote
If your a semi competent welder then make your own, mine cost about £30 materials from ebay and landrover rubbers.
Mistral Motorsport
Ugg10
posted on 21/5/14 at 07:32 PM Reply With Quote
Unfortunately that skill is not in my toolbox, thetefore my logic was - the zetec or possibly pinto may be wider than the zetec se/sigma so a couple of packing plates would both make the mounts the correct width and also act as adaptor plates between the different mounting points.
phil clegg
posted on 30/5/14 at 06:22 PM Reply With Quote
1.7 zetec
Is the 1.7 the same block as 1.6/1.8/2.0,if it's the alloy block I don't think it mates to rwd boxes,,,anyone?
