Author: Subject: MT75 and PINTO 2.0
stigofthedump
posted on 25/5/14 at 07:02 PM Reply With Quote
MT75 and PINTO 2.0
Would value some advice and guidance.
I have an MT75 Gearbox removed from an XR4 and a 2.0 PINTO fitted to my MK Indy. I have previously been told that to make this work I'll need to fit a Type 9 Clutch Lever, other people have told me that I simply need an adapter plate.
Having little experience with Ford engines and transmission I'm unsure which advice to take, also building on a budget and don't want to spend money needlessly
Thanks in advance.
r1_pete
posted on 25/5/14 at 07:46 PM Reply With Quote
Its a good few years since I built my MG with Zetec and MT75, but I'm pretty sure a twin cam Sierra thrust bearing will will work fine with the MT clutch lever and Pinto flywheel & clutch...
big_wasa
posted on 25/5/14 at 08:06 PM Reply With Quote
The gear box will bolt on just fine but you will need to play with the thrust bearing or the pivot point. The mt75 flywheel is very deep.
With a zetec fly wheel on a zetec you need an extra 20mm I don't know how the pinto compares.
stigofthedump
posted on 26/5/14 at 09:37 AM Reply With Quote
Thank you very much for that advice now i can move on with build.
Regards Pete
