Matt21
posted on 27/5/14 at 12:00 PM |
Boring out - CBR900
I've been looking into getting some engine work done.
I'd like to stick with the cbr 919 engine (or buy a 2nd 893 to do the work on) but would like to get it bored out
I've found a place that can get it to 974cc
but theres no info on what gains you actually get, can anyone give me an idea?
(im not after people telling me its a waste of money etc etc)
but if there are any real reliability issues i wouldnt mind hearing about them too
cheers!
[Edited on 27/5/14 by Matt21]
carpmart
posted on 27/5/14 at 03:27 PM |
Ive raced with this engine for six seasons. Several people in our championship chased power (cheating in the process) a few years back. They got quite
good results, Damien at Daytuner did a few for the guys. The problem is that you go from ultra reliable, as the 919 has proved itself (except the gear
box) to pretty unreliable. People have swapped out the exhaust or inlet cam(forget which one) for an exhaust or inlet, which seems to give give both
extra lift and duration. I've also tried running the 900 on a CBR600 CDi unit which gave me a 1k plus extra revs and a slightly more torquey
power delivery.
HTHs?
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
twybrow
posted on 27/5/14 at 03:40 PM |
I am not saying it is a waste of money - it is your money, you should do as you see fit. But I would be interested to hear why you are going down this
route, rather than going for a larger cc engine as stock? Would an R1/GSXR not give you similar outputs but more reliably/cheaper? Is this for a
specific race series?
Matt21
posted on 27/5/14 at 03:57 PM |
It's not for a race series no, just for road use and trackdays, eventually sprints/hill climbs. More as a bit of fun than anything else
as for just using a bigger engine, it would be nice, but believe it or not, I can get a 974cc a lot cheaper but.... if its going to be unreliable
as carpmart says then it would be more hassle than its worth
any idea on how much extra power i would get? i found one article that said around 15bhp with a 945cc kit, so im guessing maybe 30bhp extra?
do you have anymore info on using the cbr600 cdi? is it just a plug and play? no negetive effects?
and as for the valves, is that something worthwhile for me to look into on a standard engine? again any negetive effects?
drt
posted on 27/5/14 at 05:07 PM |
I suspect you're getting the 974cc big piston kit from a good manufacturer,
so the mass would be equal to the standard.
So shouldn't be less reliable
Thermal household can suffer...
But you're better of asking the manufacturer of the big bore kits,
as most builders will just go for the other bigger std engine
Horsepower gain...
Without increasing your cfm the gain will be quite small.
Torque will benefit
bigger valves, maybe cams and flowing the head
will do a lot of good.
A cbr600 cdi on a 900? Can't say I heard about that.
But the 600 revs higher(limiter) , so mind that dash
posted on 27/5/14 at 05:48 PM |
extra?
Absolutely no chance on 30bhp without a lot of additional work, and 15bhp extra just by going from 918 to 945 is pure fantasy (12.7% power increase
from a 3% displacement increase?).
Have a look at the dynobike web site. They managed to squeeze about 25bhp from a big bore kit, but
that's after porting the cylinder head, machining to get the correct CR, re-jetting the carbs and with a decent performance exhaust. One and a
half to two weeks work and $3000.
In terms of value for money a second hand 954 will look like a bargain, and give you more power.
ReMan
posted on 27/5/14 at 06:31 PM |
Not to poo poo it from a fun excersise point of view, and mine is an 893, but I remember back to my moped days when you could get a 50-65cc BIG BORE
kit!
I just could not believe the difference would be sufficient so with more entertaining things to buy when I was 16 I kept my money in my pocket!
www.plusnine.co.uk
mark chandler
Just stick a turbo on it
I,ve turned the boost up since this was done, engine is big standard apart from lockup clutch.
sam919
posted on 27/5/14 at 06:39 PM |
Have you chatted to AB about getting some more ponies by jetting etc, not a lot but you also get a smoother torque curve.
M.CH, have you done anything to the box for the extra bhp?
mark chandler
posted on 27/5/14 at 06:45 PM |
Engine is as it was dragged from the bike, on the basis that a replacement is £400 -£500 it's not worth pulling the head as gaskets add up.
I do have a spare box, just back off when notching it up a gear and use the clutch on the way down.
It has plenty of torque so you can leave in a high gear and belt around, car needed a 3.14 LSD so factor this in.
sam919
posted on 27/5/14 at 06:56 PM |
Cool, are there any recommendations for beefing things up say for track use?
mark chandler
posted on 27/5/14 at 07:31 PM |
I just fitted harder springs and fully rose jointed the suspension so I could set it up properly, then stuck on £15 second hand slicks for much
cheapness.
You need to run 13" wheels really, I have 6j with 185/60/13 on the front with 7j 205/60/13 on the rear, these cars drive around most things on
the track anyway.
Car also runs an oil cooler and accusump to help contain heat and oil surge.
[Edited on 27/5/14 by mark chandler]
MadMaxx
posted on 28/5/14 at 05:51 AM |
Is it realistic 150 bhp declared from someone simply dynojetting and with a good exaust?
posted on 28/5/14 at 06:19 AM |
Certainly not from a 918, and I think would still be optimistic from a 954.
carpmart
posted on 28/5/14 at 07:55 AM |
I managed 119.3 bhp at the wheels with a chain driven drive in my race car with a 919. It was correctly jetted with original airbox (K&N) and a
not perfect exhaust system. Optimized fully I would guess 125 bhp is the max you can get from a standard engine.
'94 MX5 MK1, 1.8
MadMaxx
posted on 28/5/14 at 08:34 AM |
Just to compare with the official figure of 128 bhp, at the fly wheel I suppose, what will be yours? 135 bhp and 140 fully optimised?
I have standard airbox with K&N with the airbox partially cutted to directly expose the filter to the air and don't touch the bonnet, so I
should expecting the same power?
Matt21
posted on 28/5/14 at 08:52 AM |
I spoke to Holeshot racing, which is who I would be using
he claims 12ftlb and 20bhp
eitherway, I dont think I would be going ahead with it as I do a lot of miles and the engine wouldnt be used as it would be built for.
sam919
posted on 28/5/14 at 10:36 AM |
The purity of the caterham fireblade in its original form is excellent a few bhp won't make much difference, its a bullet proof wee engine and
in a high state of tune per cc , you'll enjoy it better in the long run keeping it standard...
Doctor Derek Doctors
posted on 28/5/14 at 08:54 PM |
I'd also be interested to hear about the CBR600 CDI unit change, any more details?
www.t89.co.uk
www.racecarwings.co.uk
callan@t89.co.uk
mark chandler
posted on 28/5/14 at 09:03 PM |
You can also mod the ignition pickup for a little more advance which gets a bit more power running on optimax, these are designed to run on 93ron
fuel. Modified back plates used to appear on eBay for this a few years ago.
[Edited on 28/5/14 by mark chandler]
