Chris Green
posted on 11/11/04 at 01:27 PM |
Sierra Upright Insert
Hello,
On the pictures I've seen of the sierra upright insert, The tapered hole for the ball joint is offset from the centre.
Is this so the caster & camber angle can be adjusted by rotating it? or is there another reason?
Thank you!
Chris.
Andybarbet
posted on 11/11/04 at 01:40 PM |
Yep, that's exactly what it's for :-)
Some do sell them with the hole in centre but this gives no adjustment, still they are a lot cheaper if you go for the centre drilled ones ??? How
does that figure ? Still the same amount of work to make - i dunno !
JAG
posted on 11/11/04 at 01:46 PM |
A central hole is cheaper because you can make the whole thing in one operation on a CNC lathe.
For the off-set hole you have to take the part out of the lathe to put the off-centre hole in. This takes extra time and needs another jig and
drilling machine.
Justin
Chris Green
posted on 11/11/04 at 01:48 PM |
Cheers Andy,
It isn't the same amount of work to do Andy. Although it is the same amount of machining work, the tooling would have to be set up twice for the
offest hole unit.
If the hole was in the centre, it could be produced using the same setup as the outer body of the insert. All in one process.
Regards,
Chris.
EDIT: I was too slow!
[Edited on 11-11-04 by Chris Green]
Petemate
posted on 11/11/04 at 01:59 PM |
There is another (possible) reason for the hole ideally being offset - at least in the RH set-up, it avoids restrictions on suspension extension where
the range of movement in the top ball joint is compromised to the point where it wont allow the 'bones to travel to the limit of the coilover.
posted on 11/11/04 at 04:54 PM |
quote: Originally posted by Chris Green
Hello,
Thank you!
Chris.
And be aware that it doesn't actually adjust castor when you rotate it, only camber. Use the search engine to find many discussions of this!
posted on 11/11/04 at 08:20 PM |
mike is correct. to adjust castor, i would use shims around the bushes to move them about. Camber, via the transit top joint. spinnig the mushroom has
more effect on the kingpin angle.
Chris Green
posted on 12/11/04 at 07:42 AM |
Hello,
Thank you!
Chris.
Yes of course. I've just realised that!
The actual axis of the upright doesn't change does it!
Cheers Mike / Joel.
Regards,
Chris.
[Edited on 12-11-04 by Chris Green]
quattromike
posted on 13/12/04 at 04:47 PM |
HOW FAR OFF CENTER?
I was thinking of making an insert with a plate over hanging the the line of the insert to take the king pin angle right up more verticle + make it
easier to fit the transit top link on the outside but would this be too much? anyone done this?
Mike.
locogeoff
posted on 13/12/04 at 05:16 PM |
Quattromike
Is your big locost going to be as big as your avatar
Cita
posted on 13/12/04 at 05:38 PM |
Cheers Mike / Joel.
Regards,
Chris.
can somebody explain that please.
When the insert with the off center stud/hole is moved than i thought both axis where changed,or the movement of the upper wishbone going with this
change must take care of it
