charmlea
posted on 3/6/14 at 10:42 AM |
cooling system 1.6 pinto
Hi all, been reading many threads on here ref bad cooling systems on the pinto, here is my story, see if anyone can help.
my set up on robin hood
rad bottom hose to water pump
small outlet on water pump blocked off
rad top hose to thermostat [ there is no small out let on thermostat]
bottom hose on expansion tank to inlet manifold
top hose on expansion tank banked off.
when you rev engine top hose sucks in, must meen theres air in system, have filled rad by taking off top hose to get rid of air,
it has a manual electic fan. switch on dash. we did not build this, its been running for a few years now but just think that this set up is wrong,
anyhelp on this would be much appriciated.
mick reed [cambridge]
posted on 3/6/14 at 11:47 AM |
The small spigot on the water pump is an inlet it should be connected to the inlet manifold to form the bypass/heater circuit.
The top of the header tank should connect to the highest point on the cooling circuit which can be either the top of the rad or the thermostat
housing.
The lower connection on the header tank goes into a tee on the the lower hose.
Drilling a couple on 2mm to 2.5mm holes in then thermostat can help avoid airlock and thermostat not opening issues.
[Edited on 3/6/14 by britishtrident]
MP3C
posted on 3/6/14 at 12:41 PM |
Or you could connect the blanked off top hose on the header tank to the blanked off small hose on the water pump?
That's how mine is done. Seems to work fine + the 82 degree thermostat helped me a lot.
Matt
Edit: that hose that connects from the pump to the top of the header tank. When mine gets blocked with gunk (happened twice) my engine overheats
dramatically.
[Edited on 3/6/14 by MP3C]
charmlea
posted on 3/6/14 at 01:28 PM |
cheers lads for the suggestions, we are now on the case, think its 16mm pipe for the hose and we have just ordered the thermostat 82, will let you
know how we get on, mick and ash,
[Edited on 3/6/14 by charmlea]
MP3C
posted on 3/6/14 at 01:52 PM |
Wait!!! sorry not the small hose on the water pump. DUH!!! the small hose on the thermostat, if you have one. (which you don't as I have now
read XD) sorry.
The small hose from the water pump goes into the cylinder head in the middle of the inlet manifold sorry for the confusion. was half way though a
planning application at the time and my brain must have shutdown XD
Matt
charmlea
posted on 3/6/14 at 02:11 PM |
cheers mat, so what about the blanked off hose on the top of the expansion tank ?
MP3C
posted on 3/6/14 at 02:23 PM |
housing.
Matt
alfas
posted on 3/6/14 at 02:34 PM |
i think best would be to have some pictures of your enginebay.
also the exact model of your robin.
i remember on some sierra-based models with (front) inboard suspension the rad was mounted behind the nosecone, near the engine.
using the mechanical fan mounted on the waterpump , everything was fine....if such cars had been converted to electrical fan..nothing worked anymore.
charmlea
posted on 3/6/14 at 03:30 PM |
if i can figure out how to post pictures on here i will post all the pics of the pipe work, it may take a while!!!!!!
jacko
posted on 3/6/14 at 07:11 PM |
On mine
rad bottom to pump
top rad to thermostat
inlet manifold to top of header tank
bottom of header tank to 16mm pipe on water pump
this is how mine has been for about 10 years
engine 2
alfas
posted on 3/6/14 at 07:50 PM |
but thats a totally differnt car (MK indy?)...so not really transferable on a Robin...
charmlea
posted on 3/6/14 at 10:54 PM |
Looking at the indy no different to a robin, only difference I can see is that the rad has a cap on and ours does not.
alfas
posted on 4/6/14 at 10:50 AM |
your robin has for sure a different radiator, also the radiator location is for sure slightly different.
we need pictures!!!
you need to go to a picture hosting webpage (http://en.directupload.net/) , upload a picture, than you will get offered differnt links.
one of those links you copy into your posting here at the forum...job done.
you can alos use the picture-icon above
there you copy the link from the picture hosting webpage.
posted on 4/6/14 at 01:01 PM |
It is best tonavoid having two pressure caps on a system has the potential to cause air locks.
The reason is a cooling system pressure cap has two valves, one is the pressure relief valve the other is a vacuum relief valve to let air back into
the system on cooling.
As no two valves work at exactly the same pressure there is a risk that on each heating and cooling cycle the valves could work out of synch resulting
in air collecting at the wrong point of the system so that the cylinder head and rad could be full of air and and the header tank overfull of
coolant.
[Edited on 4/6/14 by britishtrident]
alfas
posted on 4/6/14 at 02:53 PM |
but there are several caps existing...the ones with 2 gaskets and 2 valves...the ones with only 1 gasket and 1 valve...and also a blanking cap, which
can look like a pressure cap...but has no valve inside....
one valve and blanking:
2 valve:
[Edited on 4/6/14 by alfas]
jacko
posted on 4/6/14 at 05:47 PM |
We are talking pinto engines not different makes of cars
The rad top on my car is blocked off it does not work as a valve
the top on the header tank lets air in and out
the tank came of a sierra
jacko
