andy188
posted on 28/6/14 at 06:55 PM |
fiesta zetec cam belt change- help
Hi all,
need some help again, doing cam belt change on shmbo fiesta 1.25 zetec, managed to get bottom pulley off (4 hrs), went to time it up, turning crank
bolt as in manual, crank going round, belt and cams not moving???, what have I done wrong and how can I fix, (I have a laser timing pin kit with bar
for locking cams and crank).
theconrodkid
posted on 28/6/14 at 07:29 PM |
the crank gear dont kave a key,it spins on the crank and the bolt holds it tight.
i am sorry to say you may have mashed the valves
who cares who wins
pass the pork pies
posted on 28/6/14 at 07:50 PM |
Remove number one and two spark plug , use a long screw driver or rod down the plug holes ,put the gearbox in top gear, jack the drivers side
front wheel ,rotate the wheel forward to turn the engine over carefully while watching the screwdriver or rod . Bring the piston up to approx halfway
up the bore then set the cams using the timing bar across the rear of the cams. Rotate the engine forward until no one piston is at TDC then fit the
crank locking pin which is found just above the O S drive shaft, you may have to rock the engine around TDC to locate the hole in the crank . This
should set the cam timing back to its original position DO NOT use the cam timing bar to lock the cams whilst releasing the cam sprocket bolts, you
will break the cams, use a cam sprocket holding tool, easy enough to make . Use these instructions at your own risk In future if changing any timing
belt always set the cam timing up before removing any crank or cam bolts
andy188
posted on 28/6/14 at 08:07 PM |
hi,
I have not removed the old belt yet, so I can take this off and set up as you have described, thanks for advise/ set up , I was not aware of the
cam timing belt pulley not being keyed, have learnt my lesson, will set up timing before removing bolts etc, is this a new thing on newer cars, used
to old transits and Peugeot diesels.
Thanks again
posted on 28/6/14 at 08:18 PM |
Lots of modern engine have the valve timing locked by crank or cam pulley locking bolts even engines with chains such as the Duratec , Renault
diesels
beaver34
posted on 29/6/14 at 02:10 PM |
make sure for gods sake that crank pulley is torqued correctly to what Ford say, otherwise they wind off and the engine lets go
