James
posted on 30/6/14 at 03:36 PM |
What inlet gasket on carb'd 205 Pinto
Having a bit of a brain fade...
I appear to have a leak from the inlet gasket of no.4 piston on my 205 injection Pinto.
However, it's got a downdraft 32/36 carb fitted.
I can't for the life of me remember which gasket I fitted before, or which one I should be fitting?
Should I use the injection gasket or the carb one? Or are the ports the same and it makes no difference?
Thanks!
James
- Muhammad Ali
jacko
posted on 30/6/14 at 03:51 PM |
At a guess i would think injection
mcerd1
posted on 30/6/14 at 03:58 PM |
injection ones are egg shaped
carb'd ones are round
so its just whichever one matches what you've got...
if you've got a head with egg shaped ports and a manifold with round ones then both will be equally bad (as you'll have the mismatched
port shapes regardless of the gasket used)
[Edited on 30/6/2014 by mcerd1]
Dingz
posted on 30/6/14 at 04:49 PM |
Use a pattern carb one not the proper ford, the 'copies' have a bit more material around the ports to cope with the miss match.
went on and on.
James
posted on 30/6/14 at 06:54 PM |
Dug around in the garage and found an injection one.
Will give that a go I guess.
- Muhammad Ali
snapper
posted on 30/6/14 at 06:57 PM |
Some gentle use of sealant helps
Just a smear on either side, push on to head, press on manifold, remove manifold, wipe excess of refit manifold, torque up
I eat to survive
I drink to forget
