scutter
| posted on 3/8/14 at 11:02 PM |
Custom Alt Pulley
Folks, I'm trying to use the standard Alt mounting bracket on the Alfa V6 with a little Denso Alternator.
  Mounted
I need the collective thoughts on the material to make an extended pulley out of? I need to bring the grooved surface 35mm forward of it's
current position. Sorry for the poor drawing, I really can't do CAD!
  Bad drawing
Steel, Alloy, titanium?
Also do we know of anyone who could make such an item?
Kind Regards Dan.
The Black Flash
| posted on 3/8/14 at 11:16 PM |
I've got almost exactly the same setup on mine, but I made a new alternator bracket to bring the alternator forwards. It seemed easier that
way. It also meant I could fine-tune the alternator's position by shimming it forwards with washers, though I only needed one in the end.
Could you do similar by mounting the alternator on the front of your bracket and adding a spacer?
I'd have thought that extending the pulley is going to increase the side load on the bearings, don't know if that would be a problem or
not.
Paul Turner
| posted on 4/8/14 at 08:10 AM |
Same here. Modified bracket to mount the small Denso on a Zetec. Much simpler (and cheaper).
Trollyjack
| posted on 4/8/14 at 08:39 AM |
Would go with modifying the bracket.
Extending the the pully will put too much strain on the front & rear bearings.
TrollyJack
mcerd1
| posted on 4/8/14 at 10:30 AM |
^^ that's what I'd be worried about too
better all round with an extended bracket
FuryRebuild
| posted on 4/8/14 at 10:31 AM |
I love the fact that you're using a turn-buckle to adjust alternator tension. I saw this done on a racing mini recently and loved the simplicity
of it. NTS, I'll be doing that.
www.furyrebuild.co.uk
The Black Flash
| posted on 4/8/14 at 10:42 PM |
Not sure if that was aimed at Scutter or myself as we both seem to have done the same!
I couldn't find one short enough IIRC, but it was easy enough to make. Bit of hex bar, a RH tap and a LH tap to thread the holes in the end,
and two rod ends (one left hand, one right - with locknuts).
I think there might have been some advertised in the back of CCC this month as well...
blakep82
| posted on 4/8/14 at 11:05 PM |
A 35mm spacer on the alternator bracket would be easier wouldn't it? Its the way I'd go
Turnbuckles and rod ends can be bought cheap from mcgill motorsports for only a few quid
http://www.mcgillmotorsport.com/advanced_search_result.php?keywords=turnbuckle&inc_subcat=1&x=31&y=17
[Edited on 4/8/14 by blakep82]
________________________
FuryRebuild
| posted on 5/8/14 at 12:06 AM |
McGills all the way. Great bunch.
