Irony
posted on 14/8/14 at 03:43 PM |
RV8 Should I change my water pump?
I have just put together my 3.9 RV8 and although I have not run it on the road yet. I have ran it up to temperature and checked the fan comes on and
the temps on the gauges are okay etc.
After more reading on websites and books etc I would like to change my 88c Stat to the Hot Climates 74 stat. Ordered it from rimmers! However my
waterpump is of unknown quality and age. It came with a scrap engine I had which had been heavily rain damaged. So I don't know its history.
The water pump however seems pretty solid and there is no movement in the bearings or unsightly rattles etc. For the sake of £45 quid should I change
it?
I also have some water on the valley gasket which I can only assume is leaking from the thermostat housing so I definitely need to get in there etc.
While I am there I am thinking of doing the performer manifold drilling mod to help things along.
mark chandler
posted on 14/8/14 at 03:55 PM |
I would not bother, pretty hardy items on the cars I have had
DW100
posted on 14/8/14 at 04:14 PM |
That very much depends on what sort of job it will be once the engine is installed should it leak.
What they really don't like is being left un-used with no water in. The bearings may not fail but the seals give up.
mark chandler
posted on 14/8/14 at 04:34 PM |
You also have the risk of the bolts shearing if you touch them, RV8 pump sits up high with easy access
posted on 14/8/14 at 05:12 PM |
Just took mine out and while theres no slack in it its quite stiff to turn. For the sake of £25 I'll be putting a new one on.
Inside the front cover looks a little nasty
Irony
posted on 14/8/14 at 08:25 PM |
It's easy to change anytime, under bonnet space is good in a viento. I have replaced all bolts with stainless already so no worries there.
posted on 14/8/14 at 09:41 PM |
Where did you get the stainless bolts from?
