Author: Subject: Effect of Plenum over Runners?
40inches
posted on 26/9/14 at 02:10 PM Reply With Quote
What would be the effect of changing the inlet from a single throttle body, with runners to each cylinder, to a single throttle body with a single plenum chamber feeding all the cylinders?
Talon Motorsport
posted on 26/9/14 at 02:15 PM Reply With Quote
Possibly a loss of torque lower down the rev range at a guess.
HowardB
posted on 26/9/14 at 02:41 PM Reply With Quote
I hope I am not missing the point of the question, but what engine does this relate to?
Howard
mark chandler
posted on 26/9/14 at 02:45 PM Reply With Quote
I guess it will depend on how clever you are with the plenum, build it with internal trumpets, think about air flow in so the rear pair if fed from the front get the same access to air with some internal ducting and you may improve things.
r1_pete
posted on 26/9/14 at 03:15 PM Reply With Quote
I'm having the same debate with myself, so building both:
This is based on the stock jag xj6 setup
Modded XJ6 Plenum 5
Modded XJ6 Plenum 5
Here's the custom job, which I must say I prefer, and you'll recognise some of the bits
ITB Progress 1
ITB Progress 1
The itbs will be harder to setup and balance, but should be less restrictive at higher rpms, plus, within reason I can vary the trumpet length to alter the torque curve.
With the plenum, balancing will not be an issue, and hopefully Jaguar got it close, but, there is a company who have proved cutting into the plenum and lengthening the runners yields a torque improvement - here
40inches
posted on 26/9/14 at 03:31 PM Reply With Quote
The engine is a Jaaaaag AJ30 I am trying to get it lower to fit under the bonnet.
The standard inlet is this monster
The Duratec V6 inlet will fit, but needs a 30mm thick spacer plate. This is lower but wider.
Something like this is what I was thinking
Once it is in, running and got a few miles under the bonnet, I will consider throttle bodies
Now where did I put those Triumph Triple bodies?
Nice, but!......... http://beta.atpowerthrottles.com/product_info.php/jaguar-injected-p-179
[Edited on 26-9-14 by 40inches]
r1_pete
posted on 27/9/14 at 01:29 PM Reply With Quote
I wonder....
I do have a couple of sets of triumph body mounting rubbers which may be of use if you go triumph bodies, I bought them planning a weber type inlet and then just went with tube and sleeves.
Pop in next time you're in Aston, you can have them if they'll help, I'm sure they fit the bodies with injector points as well as the ones I used.
40inches
posted on 27/9/14 at 02:32 PM Reply With Quote
I wonder....
I'll take you up on that Pete. Can you u2u your address please.
The Black Flash
posted on 28/9/14 at 10:16 PM Reply With Quote
Longer seems to be better when it comes to runners, so if they're very short you may lose in the midrange as said above.
As I understand it, a plenum per se shouldn't have many adverse effects, providing its volume is large enough.
v8kid
posted on 29/9/14 at 06:29 AM Reply With Quote
Me too!
Have you tried the Mondeo 3.0 rather than the 2.5 inlet? It has the throttle body tilted slightly downwards which ties in with my cunning plan to turn it 180 degrees to face forwards allowing the engine to sit closer to the bulkhead. This plan of course requires the front of the engine to be lower to follow the bonnet.
Does anyone have dimensions of how much the manifold projects above the rocker covers on the Mondeo?
Cheers!
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
Ugg10
posted on 29/9/14 at 07:24 AM Reply With Quote
There is a site if you gogle it fitting the mondeo inlet on a jag v6 in a lotus esprit, this may give you some ideas.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
Ivan
posted on 29/9/14 at 08:12 AM Reply With Quote
I've been investigating this myself this weekend and David Vizard seems to be the go-to guy for plenum and inlet manifold design.
It seems that its not so much the plenum design as the throttle body and duct leading to it that matters. With the right design of that portion utilising the Helmholtz effect you can get up to 7psi extra pressure in your plenum at certain revs.
Obviously runner lengths and area are also critical and depend on engine displacement, valve timing and rev range that you want to enhance.
There's some info here:
http://books.google.co.za/books?id=OAw1GDB0kN0C&pg=PA36&lpg=PA36&dq=david+vizard+plenum+chamber+size&source=bl&ots=C_cl6Z-vQS& sig=X2Jw2OZnycWIiZ9gDVTCZoid2iM&hl=en&sa=X&ei=T84nVNjZEovearzfgfgN&ved=0CDQQ6AEwAw#v=onepage&q=david%20vizard%20plenum%20chamber%2 0size&f=false
And also here:
http://www.gmh-torana.com.au/forums/topic/34855-intake-manifold-design/
[Edited on 29/9/14 by Ivan]
posted on 29/9/14 at 10:40 AM Reply With Quote
If you are running a single throttle body then there will be a plenum in either case, so not sure that's relevant? Shortening the runners between the port and the plenum will lose torque at lower RPM, and possibly gain you a little power at higher RPM provided the new induction system still flows well (i.e. no runners with sharp 45 degree bends in them).
40inches
posted on 29/9/14 at 11:48 AM Reply With Quote
The standard fitments not what I would call a plenum as such, first two photos, I was thinking more of the RV8 plenum in the third photo, that has a single large plenum with all the trumpets in.
I realise any move from standard will be a compromise, but it's down to space available
posted on 29/9/14 at 09:15 PM Reply With Quote
The Jag induction is still a plenum system, but because the runners themselves have significant volume the plenum volume can be smaller.
Most production cars have the longest possible runners within the given space to enhance low/mid range torque, in fact some of the small VAG engines have the runners coiled like a snail within the plenum to get the greatest length in the smallest space.
