Author: Subject: What upgrades shall I do??
AndyW
posted on 28/9/14 at 02:12 PM Reply With Quote
Hi all,
My tax runs out on Tuesday and have decided to not renew. I need to pull the flywheel off as I think the rear main is leaking. I also have a clutch issue I want to sort.
So the question is, what upgrades shall I look at to get a bit more power whilst its all out?
2.0 Blacktop running plenham and single throttle body on original ecu.
Locost options obviously the most interesting.
I've got 6 months to do it.
scutter
posted on 28/9/14 at 03:47 PM Reply With Quote
How about a straight swap ST170 lump? Plenty of info on here thanks to Wasa and quite cheap.
FORD FOCUS ST170 ENGINE WITH GEARBOX ECU AND KEY
ATB Dan.
[Edited on 28/9/14 by scutter]
perksy
posted on 28/9/14 at 08:26 PM Reply With Quote
What's it handle like ?
One of the best performance mod's is to check the suspension settings etc and adjust where required.
No point it having more power if the car isn't handling great to start with
AndyW
posted on 28/9/14 at 08:43 PM Reply With Quote
Handles great, never had a problem with that. I just fancy a bit more oomph!!
big_wasa
posted on 28/9/14 at 09:33 PM Reply With Quote
I am working on budget Turbo with oem ecu.
Already worked out the wiring.
How does 212bhp sound on a stock blacktop.
AndyW
posted on 28/9/14 at 09:49 PM Reply With Quote
Sounds tempting.....
Turbo might just be the way forward.....
