Author: Subject: Anyone made their own transmission cradle???
pewe
posted on 29/10/14 at 06:16 PM Reply With Quote
Before I bust another gut (more accurately strain/damage shoulder muscle) has anyone made their own cradle?
I want it to fit on the trolley jack as I'm working underneath, car up on axle stands.
So far I'm thinking thick piece of oblong chequer plate with a stubby rod welded centrally underneath to locate in the jack head, slot and weld four short pieces of 25mm SST horizontally to it then come up at
50 (?) degrees to approx. 150mm - job done.
Any pointers/plans/links/comments welcome.
Gearbox is MX5.
TIA.
Cheers, Pewe10
PS using SST as I have that in stock
[Edited on 29/10/14 by pewe]
mark chandler
posted on 29/10/14 at 08:30 PM Reply With Quote
I believe what you are proposing will be unstable, you need to remove the wheels on the Jack, weld on some extensions and fit with heavy duty casters.
mookaloid
posted on 29/10/14 at 08:49 PM Reply With Quote
they sell 'em on ebay if you want an idea of what they look like
Trolley Jack Transmission Jack Gearbox Adaptor Cradle Support Plate ADT200
theconrodkid
posted on 29/10/14 at 10:15 PM Reply With Quote
the jack would prob get in the way and cause more trouble than it,s worth...better to find a robust mate to give you a hand
who cares who wins
pass the pork pies
posted on 29/10/14 at 10:21 PM Reply With Quote
I made this for mine...
Badger_McLetcher
posted on 30/10/14 at 01:05 AM Reply With Quote
I bought a second hand motorbike lift for about £30, was perfect for getting the transmission out of the S-type.
New 1500lb 680Kg Hydraulic Motorcycle Motor Bike Quad Lift ATV Jack workshop | eBay
Bit expensive to buy them new though.
If disfunction is a function, then I must be some kind of genius.
pewe
posted on 16/11/14 at 07:17 PM Reply With Quote
Just in case any-one is interested I made it from an oblong piece of checker plate about 150 x 300mm, drilled two holes around the centre and clamped it the the jack head using an exhaust clamp.
Then welded six 25mm SST uprights, 3 per side about 50mm high to the plate, V notched at 90deg. at the top.
Welded horizontal SST along the length at either side into the V to help locate the box - job done.
This made life sooo much easier as all the weight was taken by the trolleyjack.
However the killer trick was using the angle guage under the sump and then on a suitable horizontal surface on the gearbox - once they were both horizontal (needed a bit of packing under the g/box tailshaft and a bit of jacking at the front of the engine) it meant the box slid into the rear of the engine like a rat up a drainpipe.
Now all I need is for the weather to turn fine and I'll be able to do all the fricking awkward bolts around the bell-housing etc. etc......
Cheers, Pewe10
PS the cradle will also double as a motorcycle lift.
PPS anyone who wants dims. or pics please PM me.
