Thatcher
| posted on 31/10/14 at 10:04 PM |
Duratec running 2001 GSXR 750 tb's
Hi all
I hope this help's you guy's when you come to space out your 2001 GSXR 750 tb's for a Duratec cylinder head you need 6 11mm spacers
for the outside ends and 3 16mm spacers for the middle and extend the linkages too.
Regards
Tony
davidimurray
| posted on 31/10/14 at 10:17 PM |
Did you find a way around the tensioner clearance in the end?
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
big-vee-twin
| posted on 31/10/14 at 10:18 PM |
Depends what manifold your using doesn't it?
http://www.triangleltd.com
Thatcher
| posted on 31/10/14 at 10:35 PM |
Yes I did David I found a C Max idler pulley thats quite small, Ford parts uk website do them for around 30 quid and I will convert the alternator
bracket to an old school style tensioner.
Hows your engine swop going?
Thatcher
| posted on 31/10/14 at 10:43 PM |
As for the manifold I am making my own so just wanted to clear the tps around the focus aux belt tensioner. Found a smaller idler pulley to give room
to the tps so that the tb's can aline up to the inlet ports on the head.
Tony.
big-vee-twin
| posted on 31/10/14 at 10:45 PM |
Like this?
[img]
  Throttle Bodies on Duratec
[/img]
davidimurray
| posted on 31/10/14 at 10:48 PM |
Still engine building at the moment, just waiting for some cam new cam buckets to arrive, after valve lapping I need 4 new ones to get everything back
in spec. Hopefully get the head back on this weekend then I can loosely get all the new timing gears.
Have you got any part numbers/photos of the st tensioner?
big-vee-twin
| posted on 31/10/14 at 10:55 PM |
Here's a pic, you will see the runner on no1 is offset to miss the tps.
[img]
  Focus Pulley
[/img]
Thatcher
| posted on 31/10/14 at 11:01 PM |
Yeah that's right but I want to avoid having to move or pull across no 1 tb for tps clearance, to keep the manifold runners all the same length
and angle in my opinion.
Thanks for the pictures.
Tony
Thatcher
| posted on 31/10/14 at 11:06 PM |
Check flak monkeys build thread as he has a picture of one that I copied ages ago but forgot I had it. If you can't find it Iet me know.
peter030371
| posted on 2/11/14 at 12:09 PM |
That could be what I am looking for. Raceline have a suitable pulley but its £95 plus VAT and delivery!
Which C Max idler pulley have you found? Do you have a part number of a picture of it?
Thatcher
| posted on 2/11/14 at 12:47 PM |
Go to fordpartsuk website and search for C Max fan belt tensioner that should return the same one I found.
Tony.
Thatcher
| posted on 2/11/14 at 12:50 PM |
Part number is 1465253.
Tony.
peter030371
| posted on 2/11/14 at 01:06 PM |
Tony.
That looks perfect and much cheaper than raceline
I best get one on order.
Thatcher
| posted on 2/11/14 at 01:10 PM |
Just need to use the alternator as a form of tensioning old school styley.......
Tony.
[Edited on 2/11/14 by Thatcher]
peter030371
| posted on 2/11/14 at 01:23 PM |
Just need to use the alternator ad a form of tensioning old school styley.......
Tony.
I have to make a custom alternator mount anyway so old school tensioner is a piece of cake
