Author: Subject: All non antifreeze users in locost.
jossey
posted on 6/11/14 at 02:58 PM Reply With Quote
Don't forget to drain your rad and engine before it freezes :-)
Common sense I know but I paniced this morning when I saw ice outside and mine is still just water.
David Johnson
DW100
posted on 6/11/14 at 03:15 PM Reply With Quote
Why not just put Anti-freeze in it?
It not only stops it freezing but also prevents corrosion, and lubricates the water pump
jossey
posted on 6/11/14 at 03:32 PM Reply With Quote
I'm waiting for a new alloy rad being made so would struggle to keep the antifreeze and it's not going to run now till the iva
David Johnson
adithorp
posted on 6/11/14 at 04:46 PM Reply With Quote
Don't forget draining it won't guarentee against freezing as it might still leave a fair amount in the block.
We had a customer a few (OK a lot) of years ago, who was so tight, he drained the rad every night and refilled every morning rather than buy anti-freeze. His block never split but the waterpump froze regularly and threw the belt of and would then over heat, eventually cooking the h/gasket.
http://jpsc.org.uk/forum/
Jenko
posted on 6/11/14 at 07:25 PM Reply With Quote
Doesnt anti freeze also also have anti corrosion properties?.....i.e. with water only is there not a risk of rusting blocks / waterpumps / etc.
MY BLOG - http://westfieldv8.blogspot.co.uk/
mcerd1
posted on 7/11/14 at 09:24 AM Reply With Quote
draining it is even worse than leaving it full of water from a corrosion point of view
for any metal to corrode it needs to be exposed to a small amount of water and a lot of oxygen
if its full of water the internal bits will get limited access to oxygen, if it drained then the damp parts will be exposed to lots of oxygen and corrode even faster.....
Paul Turner
posted on 7/11/14 at 10:07 AM Reply With Quote
For feks sake, how much does antifreeze cost. A 30% mix is adequate protection in this country and it does more than just stop your coolant freezing.
I am tight but antifreeze is way cheaper than a new engine.
40inches
When I filled the MK with water prior to the first start, and not using anti freeze knowing it would be drained, when I did drain it later, the water was very black/dark brown and it took a lot of flushing to get rid of it.
I would always use anti freeze, even for a few weeks.
Mr Whippy
posted on 7/11/14 at 01:28 PM Reply With Quote
this is how alloy heads end up with corrosion
jossey
posted on 7/11/14 at 03:11 PM Reply With Quote
It's got anti freeze in it now but I wanna make sure no one else does it. I have my rad fitted now so I don't mind spending the £10 lol.
David Johnson
