Author: Subject: Duratec Coolant System Layout
davidimurray
posted on 12/11/14 at 08:35 PM Reply With Quote
Thinking ahead for when I get on with my Duratec install, I'm going to start making a smaller water rail for the back of the head - but need to make sure I've got the correct connections.
Connection wise I think the following is correct :-
Thermostat to rad bottom
'Back of head' to top of rad
Connection behind thermostat (bypass) to back of head
Small connection on thermostat body to bottom of header tank
Top of header tank to back of head
Temp sender in back of head
Does that sound about right?
Dave
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
big-vee-twin
posted on 12/11/14 at 08:41 PM Reply With Quote
[img] Description
[/img]
http://www.triangleltd.com
davidimurray
posted on 12/11/14 at 08:47 PM Reply With Quote
Thanks Big Vee
What is the extra small red line from radiator to the top of the header tank?
big-vee-twin
posted on 12/11/14 at 10:08 PM Reply With Quote
I haven't got that, its a bleed from the radiator.
System self bleeds nicely without it.
davidimurray
posted on 13/11/14 at 10:27 AM Reply With Quote
Just after I posted I had the same thought!
