Author: Subject: Zetec Oil Pressure Switch - Connector Identification
Tatey
posted on 15/11/14 at 07:25 PM Reply With Quote
Evening all,
I am currently trying to locate a connector block for my Zetec Oil Pressure Switch which looks like the following:
VE706051 Ford Focus Zetec MK II 1.6 Petrol 04 Oil Pressure Switch
Does anyone know what this kind of connector is called or is it a Ford specific one? In either case will it be possible to buy the other side of this connector? If not is it the case of finding a spade connector (female) which will plug into this or getting hold of another compatible sensor with a DIY friendly connector on it?
Dooey99
posted on 15/11/14 at 07:36 PM Reply With Quote
go to a scrappy and ask for the plug off an old wiring loom and cut it with a few inches of wire on then just solder it on the end. thats what is do
Less weight more speed, more power more speed
If in doubt, give it a clout
19sac65
posted on 15/11/14 at 07:37 PM Reply With Quote
Have you no local breakers yards
Take the switch with you to make sure the plug fits ,then snip it off
I doubt if they would even charge you
T66
posted on 15/11/14 at 07:46 PM Reply With Quote
An ebay search for "zetec breaking" always works.....
Apply it to whatever your after, then email the seller for the specific part.
Ford Fiesta 03 Breaking Zetec
davidimurray
You can get them for free quite easily .........
http://locostbuilders.co.uk/viewthread.php?tid=194663
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
Tatey
posted on 15/11/14 at 09:44 PM Reply With Quote
Thank you very much for all the replies. I really hadn't considered the idea of getting one from a breakers. I've emailed TE Connectivity to get a free sample, if that doesn't work ill be heading down to my local breakers.
davidimurray
posted on 15/11/14 at 09:47 PM Reply With Quote
You just need to register with TE then use their sample ordering system.
Or buy from Mouser - http://uk.mouser.com/ProductDetail/TE-Connectivity-AMP/184042-1/?qs=sGAEpiMZZMvt1VFuCspEMhsCqXACm5kc
[Edited on 15/11/14 by davidimurray]
