v8kid
posted on 21/11/14 at 07:51 AM |
What size twin throttle bodies on jag V6?
In trying to lower the height of a jag 3.0 V6 which has a huge inlet manifold - mainly to increase torque which is not so important in a lighter car
so I am looking at using twin throttle bodies - one each side of the engine but what size is appropriate or indeed is it that important?
I guess that it is not just the case of making the total area the same as the uneven gas flow from 3 cylinders as compared to 6 cylinders will flow
less efficiently. Also would there be benefits from increasing the flow area anyhow compared to standard?
There is quite a bit of info available on carbs but it is not relevant as they have to maintain a fast airflow for the venturi effect to vaporize the
petrol.
Also the choice will be affected by what is available at a reasonable price.
Any guidance in the collective?
Cheers!
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a
chainsaw
Ugg10
posted on 21/11/14 at 08:10 AM |
If you do a search there is quite a bit of info on a jag v6 install in a lotus esprit. He initially tried bike tbs but then fitted a st200 inlet onto
the jag engine to lower the height. The omega 3.2 v6 had a twin throttle bodi iirc. There is also info on tb size on the jenvey website, that may give
you an idea.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
