Author: Subject: Zetec Spigot Bearing
stevebubs
posted on 24/11/04 at 07:34 PM Reply With Quote
Guys,
Is there currently a spigot bearing in the
end of my crank (see pic) or not?
Thanks in advance
Stephen
www.cantcatchme.net
theconrodkid
posted on 24/11/04 at 07:54 PM Reply With Quote
nope
who cares who wins
pass the pork pies
stevebubs
posted on 24/11/04 at 07:55 PM Reply With Quote
Wierd...does the Mk2 mondeo not have a spigot bear then? The engine is as removed from the car...
garage19
posted on 24/11/04 at 08:09 PM Reply With Quote
None of the zetecs have a spigot bearing in the crank as stock.
Luckily for machined the recess in the end of all the cranks to allow fitment of one for rwd applications!!
Burto power will flog you he correct one for about a fiver. Just warm the crank up, put the bearing in the freezer and then press it in square with the correct size socket.
stevebubs
posted on 24/11/04 at 08:12 PM Reply With Quote
Already got one from Dunnell, but didn't want to push it in until I was sure nothing needed removing!
Cheers, guys
Stephen
zetec
posted on 24/11/04 at 09:32 PM Reply With Quote
Get it the right way round. Problem is I can't remember which way it goes. If i remember right there is a small oil seal one end.
stevebubs
posted on 24/11/04 at 09:44 PM Reply With Quote
Yeeks - hadn't noticed it wasn't symmetrical.
I'm Guessing the rubber(ish) ring is a seal to prevent rubbish getting in so faces out...
garage19
posted on 25/11/04 at 05:19 PM Reply With Quote
Thats the way I've done mine.
I checked with Burton Power first to make sure!
