Author: Subject: one way butterfly valve
Craigorypeck
posted on 22/1/15 at 04:52 AM Reply With Quote
Hey all.
My latest engine build is going to be a twin charged effort.
For shits n giggles really...
In the effort of mechanical simplicity im looking for a one way butterfly valve.
Im not after a bypass valve actuated by a solenoid nor ref from vac/boost but a simple off centered eccentric valve that will flow air one way only
Like a throttle body with spindle shaft offset to one side..
Ive looked online all eve and found nothing.
Anyone know where to find such an item say in 2" I/D
Many thanks!
NigeEss
posted on 22/1/15 at 08:35 AM Reply With Quote
Try looking for a flap valve or duckbill valve.
rdodger
posted on 22/1/15 at 08:41 AM Reply With Quote
I realise you have said you don't want to use a bypass but.......
Have you considered using EBC valve or even a manual one to bypass the supercharger at a chosen boost?
I guess you want a small supercharger from low down then turbo will take over and the supercharger will be bypassed using your one way valve?
Ugg10
posted on 22/1/15 at 09:05 AM Reply With Quote
Is there one of these in the VW twin charge engine that you can get from a scrappers ?
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
mark chandler
posted on 22/1/15 at 09:57 AM Reply With Quote
Two stroke reed valve
[Edited on 22/1/15 by mark chandler]
Oddified
posted on 22/1/15 at 10:03 AM Reply With Quote
Is this going on the NA Cossy engine that you boosted with an Eaton supercharger a while ago?, or another project.
Ian
Craigorypeck
posted on 22/1/15 at 01:18 PM Reply With Quote
Forgot how to multi quote but thanks for the suggested search ideas will get on that tonight.
The charger will feed the turbo and will also keep the one way valve shut until the turbo spools more than the eaton can supply so when negative pressure is seen by the one way valve it just simply falls open. No pressure switches, no fiddling with the db15 outs on the megasquirt to try and control it all.
The charger will not be disengaged but still run as normal.
This is another project. The blown cossie is back home in Ireland. Im now in canada. Using a 2.3 lima
Craigorypeck
posted on 23/1/15 at 03:36 AM Reply With Quote
Well I did find a one way check valve. 2 1/2" available in all manner of materials with a selection of different rubber seals.
Thinking of an all aluminium body and aluminium blades with a viton rubber seal.
This should allow the turbo to draw air past the charger and not give any noticeable switch over like twin charged setups sometimes have.
Comments?
http://www.thevalveshop.com/menu/manual/techno/eht.html
rdodger
posted on 23/1/15 at 11:36 AM Reply With Quote
Have you got a sketch of how you propose to plumb this up?
I'm having trouble imagining how this will work
coyoteboy
posted on 23/1/15 at 12:47 PM Reply With Quote
Yeah im needing a diagram for this. I'm in the early stages of twin-charging too but im using the tubby to feed the blower and using the oem electronic bypass on the SC
https://www.fixmystreet.com/
Craigorypeck
posted on 23/1/15 at 01:02 PM Reply With Quote
Here's a (very) rough sketch whilst eating my breakfast.
Ugg10
posted on 23/1/15 at 01:09 PM Reply With Quote
What are the benefits of running them in series rather than the usual parallel?
If I were doing this I would have used the parallel route with an ecu (rpm/load) operated valve to select the supercharger output at low rpm and turbo at high, the supercharger could be opersped (overspeeded?) and dropped out with another ecu switch using the Mercedes clutched pulley to get a bit more boost low down.
Craigorypeck
posted on 23/1/15 at 01:18 PM Reply With Quote
Yes thay does sound good. Thought about that but my idea is for simplicity. No switches between the two systems, no noticeable switch over as the one way valve simply opens when the charger becomes a restriction.
My m62 doesn't have a mag clutch.
r1_pete
posted on 23/1/15 at 02:40 PM Reply With Quote
As others have said try the two stroke reed valve, Suzuki RG500, Yamaha TZ etc...
You say you want 'Like a throttle body with spindle shaft offset to one side' you can't do this, if you move the spindle off centre the disc cannot open, as its widest part will try to sweep into a narrower part of the tube, unless you step up the diameter of the tube at the fulcrum point.
coyoteboy
posted on 23/1/15 at 04:11 PM Reply With Quote
Two stroke reed valve is gonna produce large efficiency drops IMO. Better to do it the way all the OEMs do it and use either a vacuum switched or electronically controlled option.
What sizings are you using for the super/turbo combination? I did it turbo blowing into super because that way my peak power is primarily limited by the size of the turbo (not wanting to swing a big super off a relatively small engine).
Craigorypeck
posted on 23/1/15 at 04:32 PM Reply With Quote
I have an m62 from a cobalt and a t4 turbo.
Im concerned with having the blower after the turbo as it will really heat the poo out of the boost and were really into compound charging then. The way im trying to go about it gets the charger out of the system (well sort of) in the upper rev range. A boost gauge between charger and turbo and another gauge after turbo would show when the charger goes out of use and running turbo only. It should seamlessly glide from compound to the turbo being primary?
Oddified
posted on 23/1/15 at 05:39 PM Reply With Quote
I like the idea, no reason not to think outside of the normal box. I don't see a 2 stroke reed valve working at all well in this application, but i don't see any reason the valves you linked to won't work.
Ian
coyoteboy
posted on 23/1/15 at 06:08 PM Reply With Quote
This is parallel charging not compound (as the turbo is bypassing the SC) Ugg. The issue I see is that the reed valve will pose a restriction, it will take some positive flow (and boost/restriction) to hold it open. If you just use a vac actuator that compares the SC output to the turbo output (pre valve) it can be made to open entirely mechanically when the tubby is producing more boost than the SC can. The issue you woud have with any of them is when the reed/vac valve opens,the boost from the turbo will drop momentarily (less restriction) and the valve shut. You're going to get oscillation/chatter which may affect drivability around that point. Assuming you size the tubby MUCH higher than the SC and boost hard right through it you probably wont notice.
The benefits of compound charging are that you get massive pressure multiplication, at the expense of efficiency drop. (boost multiplies but so does efficiency loss). PArallel systems like this give the low boost of a SC at good efficiency, then bring in the turbo at higher efficiency, meaning the peak boost will be lower but the overall system efficiency higher.
This is the route I am taking (though that's still reliant on me being able to fit the eaton under the bonnet, which isn't looking likely just now...)
NoRoom
NoRoom
[Edited on 23/1/15 by coyoteboy]
rdodger
posted on 23/1/15 at 08:20 PM Reply With Quote
I thought that's what you meant.
Be good if it does work. Brilliantly simple.
The hard work will be getting the blower mounted and all the packaging sorted so a bit of re plumbing if it doesn't it will be easy.
Keep us up to date with progress.
Craigorypeck
posted on 23/1/15 at 08:50 PM Reply With Quote
Not too fussed on the reed valve. I want a nice open valve that will flow nicely when open. Not even gonna have a spring on it.
I don't see a chatter or stumble issue as if say the charger is making 8psi through the turbo. The turbo spools up and creates 8psi, as it climbs psi the one way valve opens and the turbo draws air past the charger. This fresh air mixed with an unpressurised charger supply will be nice n cool
If this valve was controlled via boost ref or electronically I can see it stumbling or having issues as finding that sweet spot will be a challenge?
In my mind this is incredibly simple... maybe too simple.
Now coming off WOT... I havekno idea how it will perform!!!
rdodger
posted on 23/1/15 at 09:43 PM Reply With Quote
Coming off WOT should be ok as the bypass will open and the dump valve will dump so if the butterfly valve bounces about you won't notice.
Well let's hope not
