Author: Subject: Injector Cleaning
pewe
posted on 23/1/15 at 02:54 PM Reply With Quote
Injector Cleaning
The hairdressers has developed a flat spot at around 4500rpm.
Replacing the plugs has had no effect.
Next in line the injectors, mainly because I haven't touched them in 3 years and it runs rich due to lack of an intercooler.
There's no-one local to Reading who provides servicing/flow testing.
Having spoken to him this guy seems to know what he's doing and at £12.50 per injector his prices sound right.
He can not only advise on injectors but supplies new ones and service kits.
http://mrinjectoruk.co.uk/
I'll post up once I receive mine back.
Cheers, Pewe10
prawnabie
posted on 23/1/15 at 03:09 PM Reply With Quote
Ive used him before, no complaints really and it did cure a misfire.
CosKev3
posted on 23/1/15 at 04:24 PM Reply With Quote
http://www.injectorcleaning.co.uk/faq.htm
Used the above a few times,fast service and they send you back all the old parts and flow charts for injectors.
perksy
posted on 23/1/15 at 05:37 PM Reply With Quote
As Coskev3 above
I've also used them a few times and been impressed by the service
rodgling
posted on 23/1/15 at 09:08 PM Reply With Quote
injectortune.co.uk for me - similar price, prompt turnaround. No complaints, although I was surprised that they were all within ~3% before cleaning, given that they're off a 18 year old car... so wasted money? Dunno but it's good to know they are all 100% healthy.
pewe
posted on 24/1/15 at 10:21 AM Reply With Quote
I think having someone who can properly service and test them has got to be worth the money.
OK you can check resistance and squirt cleaner through them using 12v and a clicker switch but it's not as if you can a) clean them properly - don't know about you but I never realised there's a micro filter in the injector which can block or b) test them for flow rate under pressure.
Cheers, Pewe10
CosKev3
posted on 24/1/15 at 11:33 AM Reply With Quote
I had a cavalier sri130 fitted with the 8v seh engine years ago, had the injectors cleaned locally and he ended up putting them through the ultrasonic clean 8 times to get them all equal.
I refitted them and my Co at idle was up to 7.3%, he reset this and the car was transformed,the power was loads more linear, nice and smooth all the way through the throttle movement.
