melly-g
posted on 27/1/15 at 08:53 PM |
flywheel
How do you check a dual mass flywheel? It's off the car!
Ben_Copeland
posted on 27/1/15 at 08:59 PM |
Just bin it and get a solid conversion one.!
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
dave_424
posted on 27/1/15 at 09:05 PM |
I believe check its general condition, if it rattles like a tambourine then possible that the springs have been over compressed and now allow more
free play. I think VW states that the 2 masses should not be able to be rotated by hand more than 8 degrees. I've got to do the same soon so
have read up on it a bit but am not really that experienced
posted on 27/1/15 at 09:17 PM |
according to an LUK poster on our workshop door the rotational play should be between 10 mm and 30mm with IIRC a max 4mm play rocking top to bottom if
that makes sense. I have fitted a couple of solid conversions without any problems although I have read about broken cranks when solid flywheels have
been fitted I haven't seen any myself or know anyone that has
melly-g
posted on 27/1/15 at 09:46 PM |
I don't seem to be able to find a solid conversion? Where is best to look?
Solid should be OK on the duratec, but I don't want lightened on a cmax really.
jollygreengiant
posted on 28/1/15 at 10:17 AM |
As posted in your other post & I U2U you about my reply(s)
Click the LINKY LINK
