Author: Subject: Siezed Clutch
myke pocock
posted on 15/2/15 at 11:04 PM Reply With Quote
Siezed Clutch
1300 x flow with Sierra 5 speed box. Came to get things running for the good weather and found the clutch plate seized on. Can I get access through the large clutch cable operating gaitor on the side of the gearbox to unsieze it in some way or is it an engine out jobbie?
mark chandler
posted on 15/2/15 at 11:36 PM Reply With Quote
Get someone to tow you around in 2nd gear, if no joy try 1st with you foot on the clutch, engine off but not so the steering is locked!
scott h
posted on 16/2/15 at 12:07 AM Reply With Quote
Run the engine for a while to get some heat to the flywheel. Then on some private ground select first gear and with your foot on the clutch pedal start the engine, it will help to have a couple of assistants pushing. The car will move off but keep your foot on the clutch pedal and blip the throttle. To stop you must switch off the engine if the clutch is still stuck! Try a few times and if it fails then let the engine cool overnight before doing it all again, the heating and cooling cycle should hopefully do the trick. A couple of days spent doing this is better than having to take the engine out so be patient.
Slimy38
posted on 16/2/15 at 08:31 AM Reply With Quote
It was also suggested to me to apply the handbrake, although I guess that would put the entire load on the starter motor? It was on a knackered Cavalier so probably a little less value than a kit car!
John G
posted on 16/2/15 at 08:32 AM Reply With Quote
Clutch
Years ago I had an MG Midget clutch stuck as it had been rebuilt over a couple of years. I removed the starter motor and used a paint stripper hot air gun (electric not flame ) to heat up the flywheel. Worked a treat!
The Black Flash
posted on 16/2/15 at 02:26 PM Reply With Quote
A variation of the above I've used to free a stuck clutch on an MGB.
Foot on clutch pedal, turn the starter - the car will lurch forwards. Quickly jump on the brake while its still moving. That locks one side of the clutch while the momentum of the engine and flywheel is still moving. In my case it came unstuck after about 4 goes so it's worth a quick try. If not then see if you can bump start it as above and get some more power into it.
myke pocock
posted on 17/2/15 at 06:28 PM Reply With Quote
John G the heat trick worked a treat. Many thanks.
