Author: Subject: V6 exhaust link pipe size?
40inches
posted on 17/2/15 at 12:56 PM Reply With Quote
The main tubing is 2". How small can you go in link pipe diameter? 38mm would be easier to run than 2"and could be in Polylock.
Badger_McLetcher
posted on 17/2/15 at 05:07 PM Reply With Quote
From the research I've been doing for mine, it appears you want to keep it as large as possible (up to the system diameter). I guess go with the maximum you can fit.
Out of interest where are you putting your link pipe? I'm figuring it'll have to be after the collectors and run under the car on mine.
[Edited on 17/2/15 by Badger_McLetcher]
If disfunction is a function, then I must be some kind of genius.
40inches
posted on 17/2/15 at 06:13 PM Reply With Quote
I'm running it under the sump, and as you say after the collectors, I have fitted the X-Type/Mondeo sump, there is a cut out under the sump that the front drive cars use for the front pipe to run towards the back.
v8kid
posted on 17/2/15 at 06:30 PM Reply With Quote
Oh! that's the first I've heard of polylock. I've seen flexible hose but it always had packing in between the corrugations and the polylock page says it is packing free. Is it readily available?
Does it weld OK?
Cheers!
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
40inches
posted on 17/2/15 at 06:42 PM Reply With Quote
Does it weld OK?
Cheers!
Available on eBay, but, strangely, the cheapest I have found is Car Builders Solutions
It welds fine and is sold by the ID, it can be twisted to slightly increase/decrease the bore size. It is smooth inside and out, I believe it clamps up on a pipe without leaking.
[Edited on 17-2-15 by 40inches]
v8kid
posted on 18/2/15 at 08:28 AM Reply With Quote
Ta I'll give it a go
DIY Si
posted on 18/2/15 at 03:35 PM Reply With Quote
I'm doing another option for my link pipe. I'm not using one at all, as such, but instead I'll be using a X piece in the exhaust down stream of the collectors. It should help a little bit more with the scavenge effect and saves me having to fart about with a link pipe.
Sun Tzu, The Art of War
