joni
| posted on 17/2/15 at 04:02 PM |
Westfield rear brake disc light weight
Hi guys has anyone ever made there rear disc light weight just weighed one there and it came in at over 3 kg
I think the disc are of the front of a mk3/4 escort
Any help guys
lsdweb
| posted on 17/2/15 at 04:49 PM |
I've used the mk3/4 escort / Fiesta discs on the rear of a '7' style car (live axle) before and doing the same again now - if you
use relatively light calipers, the overall weight works out at roughly the same as a set of drums. I'm not sure how much weight saving is
available in the disc.
Wyn
Ben_Copeland
| posted on 18/2/15 at 09:28 AM |
I run vw alloy rear calipers and solid cosworth rear discs. Fairly lightweight solution
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
lsdweb
| posted on 18/2/15 at 10:42 AM |
Just found the weights of the various parts - http://www.locostbuilders.co.uk/viewthread.php?tid=33379
This is for a live axle car and the whole lot fits under 13" wheels (which is one of my main aims with the Striker).
Wyn
  Rear caliper conversion 3
  Rear caliper conversion2
Angel Acevedo
| posted on 19/2/15 at 02:37 AM |
Thread Hijack
Would skimming disks to minimum thickness as original car specs (Maybe a mm less) save enough weight to be acceptable?
Would this mod render the disks more prone to faillure?
Any concerns at MOT time?
Best regards.
Angel Acevedo
