Author: Subject: Duratec burning or losing oil..
mcerd1
posted on 26/2/15 at 01:32 PM Reply With Quote
My bog std 1.8 duratec in the tintop has started losing oil
I've got no obvious leaks and no obvious oily smoke either - any ideas what to check next?
ali f27
posted on 26/2/15 at 01:54 PM Reply With Quote
Hi i made the mistake of not stripping mine when i bought it just put it strait in and it burned oil like a pig so took it out and stripped it rings wear absolutely coked oil ways blocked etc cleaned it put new rings on and honed bores now runs like a new one if there are no drips on the floor must be burning it
Stot
posted on 26/2/15 at 03:40 PM Reply With Quote
PCV valve stuck open?
Stot
posted on 26/2/15 at 07:35 PM Reply With Quote
A cylinder leak down test would confirm piston ring or piston problems, much more definite than a compression test.
