Author: Subject: Oil extraction pump TDI Jeep
joneh
posted on 28/2/15 at 03:27 PM Reply With Quote
I have a Jeep Pat due its service. It has the VW TDI engine. I've tried oil extraction using a pump but the plastic hose doesn't reach right down the bottom and sticks.
Does anyone know if the dip stick tapers towards the bottom? If so I'll see if I can source a narrower tube.
Jon
posted on 28/2/15 at 03:48 PM Reply With Quote
Originally posted by joneh
Jon
Pela 6000 (also sold under different bend names) vacuum extractors us a flexible steel suction pipe that gets to bottom of the sump of any vehicle I have tried it on.
[Edited on 28/2/15 by britishtrident]
joneh
posted on 28/2/15 at 05:44 PM Reply With Quote
Ok thanks, looks like the steel probe is only 3/16 (about 5mm). The eBay jobbie I have the smallest hose is around 9mm
Will order a pela and eBay this one.
whitestu
posted on 28/2/15 at 06:20 PM Reply With Quote
+1 for the Pela 6000.
I'm sure the pipe on these is actually an outerbrake cable from a bike.
Stu
big-vee-twin
posted on 28/2/15 at 10:41 PM Reply With Quote
I use a Mannesman on my Pat has a thin plastic tube
http://www.triangleltd.com
joneh
posted on 6/3/15 at 11:52 AM Reply With Quote
Got a Pela 6000 from the local yacht chandlery and it worked a treat.
On another note, could the engine bay of the jeep pat be the worse designed bay ever? Right pain to get to basic service items.
