Author: Subject: Driveshaft lash?
tegwin
posted on 6/3/15 at 10:14 AM Reply With Quote
Driveshaft lash?
Doing the normal crawl around under the tintop during its service I grabbed hold of one of the driveshafts (Front wheel drive) and there appears to be a fair bit of rotational play in it. I assume this is not normal?
Can these things be "rebuilt" or would it be wiser to simply replace the entire thing. The one on there is 14 years old and a bit rusty. Can't say I have ever done one....
Would a sloppy driveshaft explain why I get driveline shunt as I lift off the accelerator do you think?
www.verticalhorizonsmedia.tv
Slimy38
posted on 6/3/15 at 10:47 AM Reply With Quote
Last time I had a dodgy driveshaft I just got a second hand one off Ebay. One nut on the wheel, six bolts on the gearbox, some 'enthusiasm' on the splined shaft to dislodge it then replace it.
adithorp
posted on 6/3/15 at 01:35 PM Reply With Quote
You can repace the CV joint or fit a recon' shaft. Worth pricing both as the price difference is sometimes so little it's not worth the effort to change just the joint.
PS... depends upon the design/make as some shafts don't have removable joints.
[Edited on 6/3/15 by adithorp]
http://jpsc.org.uk/forum/
