dr-fastlane
| posted on 28/11/04 at 03:13 PM |
engine/gearbox brace
I've got a 2.0l Ford Sierra OHC injection engine and a type N-gearbox in mine Seven. But there is no brace between teh engine and gearbox.
Is it nessesary to have a brace between the engine and gearbox?
At witch site of te engine is it normaly placed? Maybe a picture can help.
I have not failed once. I have successfully found ways that will not work!
https://www.motor-forum.nl/threads/hardtail-dragstyle-project.343482/
| posted on 28/11/04 at 11:42 PM |
It's on the opposite side to the starter from one of the bottom bellhousing bolts to the block. My nephew has a 1.8cvh Sierra which doesn't
have one on and it does slacken its bellhousing bolts off occasionally causing clutch problems. He should loctite the bolts but can't be @rsed.
It's just a piece of bar about 18x4mm, scan here.
dr-fastlane
| posted on 29/11/04 at 06:33 PM |
Thanks!
The sump I use has a extra box added to the side to restore lost oil capacity after reducing the height. Now there i've got no place for the
brace, hmmmm
