Dave Bailey
posted on 13/3/15 at 08:24 PM |
Type 9
Hi all I have a type 9 5 speed and I have had to drain it due to an oil leak... Looking at the Haynes type 9 the 5 speed has two capacities 1.23l and
1.75 or something... I always thought it was fill it until on level ground the oil runs out the plug on the side. I have also heard that you fill it
to this level then remove some because of overfilling... I have put a quaife top cover on with a vent so shouldn't be pressurising the box...
Any advice?
Dave B
posted on 13/3/15 at 08:30 PM |
I think the early type 9 boxes had a higher filler/level plug than the latter boxes, I'm sure I've seen photos comparing the height of the
filler bungs somewhere , possibly on this forum?
obfripper
posted on 13/3/15 at 09:39 PM |
There are 2 different positions the bung can be in originally, giving the 2 different capacities.
I had the lower bung, when i installed a tran-x gearkit i added a higher bung, as the higher oil fill level was recommended.
I think the v6 and diesel boxes had the higher bung position as standard, all my spare boxes have the bung in the lower position, but are from
pinto's.
You should be fine filling to your existing bung level though.
Dave
Dave Bailey
posted on 13/3/15 at 10:33 PM |
Thanks for the replies guys....
Dave B
scimjim
posted on 13/3/15 at 10:37 PM |
The Sierra manual says:
All five speed gearboxes up to April 1984 except those subsequently fitted with a modified extension housing: level with bottom edge of filler hole
All five speed gearboxes from May 1984 to end of April 1985 and all vehicles built up to April 1984 and subsequently fitted with a modified gearbox
extension housing: 20.0 to 25.0 mm below lower edge of filler hole
All five speed gearboxes from May 1985: 0 - 5.0 mm below lower edge of filler hole
I've always filled them until it overflows
