posted on 22/3/15 at 06:35 PM |
cooling question
Volvo 850 T5
Replaced coolant temp sensor and coolant, approx 50/50 glycol/deionised water.
Next days commute (4 miles) noticed car takes longer to warm up, needle reaches 3 o clock pos and sits there, used to take about 10 mins but took
20.
Did a longer journey today at higher speeds 15 miles and needle reaches steady state but never got over 4 o clock. Air coming out of vents does not
feel as hot.
If car is left stationary needle will reach 3 o clock and fan keeps it there so i dont think the cts is faulty.
Surely a coolant change cannot account for this, afaik it was the original stuff that is 20 yrs old. Thermostat was not touched.
Should i be concerned?
I will get IR thermometer to measure coolant temp.
[Edited on 22/3/15 by 02GF74]
theprisioner
posted on 22/3/15 at 06:42 PM |
Air lock in heater hose is my guess
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
posted on 22/3/15 at 06:44 PM |
Air lock
posted on 22/3/15 at 06:50 PM |
Hmmmmm.... need to read manual. I thought itd be self bleeding and just filled via the expansion tank.
No special steps mentioned in manual.
Dont airlocks cause overheating?
theprisioner
posted on 22/3/15 at 06:55 PM |
RTFM is good place to start
posted on 23/3/15 at 08:24 AM |
Been pondering over this, thermostat stuck open would cause this, change of coolant being coincidental?
theprisioner
posted on 23/3/15 at 09:46 AM |
Take the feed pipe to the heater matrix at highest point possible, release pipe clip and partially remove pipe till coolant emerges.
