belgian2b
posted on 31/3/15 at 11:09 AM |
zx12 spark plug
Hello,
my Zx12 engine (Westfield XTR2) is running with NGK CR9EKPA spark plugs.
I have to change them quite often if i do not rev the engine ( for example when i run the engine for some minutes in wintertime).
but they are quite expensive.
So do you know where i can buy them at a low price , or is there any alternative ?
Gerardo
twybrow
posted on 31/3/15 at 02:54 PM |
I am surprised, as I have run the same set for more than 2 years now! When you say you need to change them, what effect is this having on your
engine/running?
belgian2b
posted on 31/3/15 at 03:08 PM |
Hello,
my KMS ECU is programmed quite rich, so if the engine is not used at high revs, the plug quick cover with "carbon" layer.
So engine is very difficult to start from cold.
As soon as i change them, i starts again perfectly.
Gerardo
wylliezx9r
posted on 31/3/15 at 04:29 PM |
Why not adjust your mapping then ?
George Best
Slimy38
posted on 31/3/15 at 08:50 PM |
Or clean them?
