Author: Subject: Duratec idle issue and co2 issue
hiwex
posted on 4/4/15 at 06:47 PM Reply With Quote
Hi Guys,
I have a standard duratec that used to run just fine.
After a fast run back in the summer I noticed is was ticking over badly and almost stalling, then just catching.
Tickover varied between not much and over 2000 revs, it would sit there, revving itself.
I also noticed a change to the exhaust note, sort of nasel like and a bit of a smell of sulphur or something like that.
All this was just an inconvenience until I took it for its MOT today and it failed on high CO2 on idle, it should have been less than 3,000 but was never less than 5,000.
Are there any Duratec experts out there who can work out what's wrong from my description?
Oh yes, and the ECU warning light came on on the way home.
Mike
posted on 4/4/15 at 07:45 PM Reply With Quote
CO2 isnt tested during an MOT at present, do you mean CO?. makes a huge difference
hiwex
posted on 4/4/15 at 07:57 PM Reply With Quote
Yes, CO.
Mike
davidimurray
posted on 4/4/15 at 08:47 PM Reply With Quote
To have a CO that high suggest it is very rich -
I've been working on mine today and setting it up on bike carbs. My AFR is about 13.5 with a CO of around 1.9%
What is your setup? ECU? Throttle bodies or single throttle? Are you running a lambda sensor / closed loop?
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
hiwex
posted on 5/4/15 at 07:36 AM Reply With Quote
I'm running a crate engine, totally standard and factory ECU. Ive just arranged to borrow a fault reader, hopefully that'll help locate the issue?
My other car runs ITB's and Megasquirt, I can adjust that, but not this one......
Mike
