madteg
posted on 15/4/15 at 08:14 PM |
Air Gap
Have had to put a trigger wheel on my Jeep Cherokee, does anyone know what the air gap size should be. I am using the standard Crank senson and
toothed wheel. Thanks Kev.
Chris_Xtreme
posted on 16/4/15 at 07:22 AM |
this is for the ford sensor:
The Ford VR sensor (Crank sensor) MUST line up with the teeth at 0.75-1.0mm on every tooth,
taken from
http://www.extraefi.co.uk/wheel_fitting.htm
( in case you were asking generically rather than specifically for the jeep sensor - but I should imagine the same)
