Author: Subject: Duratec Engine change
neilp1
posted on 5/5/15 at 06:55 PM Reply With Quote
So the Duratec I have in is smoking. I bought an engine a while ago which I was going to re-build with forged pistons/rods etc. this engine came with a goosed top end (run on LPG apparently) so I've bought yet another engine as the smoking engine is getting worse.
So the question is do I stick the most recent purchase in and risk having an engine similar to what is in or do I give it a re-fresh (new rings, bearings etc)?? I don't have a budget at the moment for forged pistons/rods.
Neil
ali f27
posted on 5/5/15 at 07:45 PM Reply With Quote
Clean it up hone the bores and re ring it make sure you clean the pistons really well cheap and will be spot on again
davidimurray
posted on 9/5/15 at 09:11 PM Reply With Quote
Try a few Duratec engine builders - I found a set of brand new rods, pistons, rings and bearings stripped from a new crate engine for £35 + p&p.
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
neilp1
posted on 10/5/15 at 05:11 PM Reply With Quote
Cheers for the input guys.
I'm going to take the chance and drop this engine in and rebuild the bottom end of the engine thats currently in as I know thats burning oil.
