paul_mcq
| posted on 3/12/04 at 03:13 PM |
telll me wat you's think
well lads need a new inlet mani and decide to put my uni coarse to good use by designing a new one. tell wat you think of the drawing so far. remember
its not finished
[img][/img]
Crazy Jay
| posted on 3/12/04 at 04:11 PM |
Funky. Now u hav to make it
Check out the exhaust this guy MADE!
http://www.locostbuilders.co.uk/viewthread.php?tid=19230&page=1
[Edited on 3/12/04 by Crazy Jay]
Volvorsport
| posted on 3/12/04 at 05:34 PM |
need some radiused corners on the entry to those runners !
paul_mcq
| posted on 4/12/04 at 03:30 AM |
did a bit of work on it still not to scale but gives you the idea
Rob Lane
| posted on 4/12/04 at 09:04 AM |
Check this out for a practical build.
http://www.sdsefi.com/techinta.htm
paul_mcq
| posted on 4/12/04 at 05:15 PM |
great web site cheers rob
paul_mcq
| posted on 4/12/04 at 09:39 PM |
my new improved drawing and with fuel rails and injectors
paul_mcq
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=inlet%20mani%203.JPG
paul_mcq
| posted on 4/12/04 at 09:42 PM |
i think this pic will work still trying to get a hold of it
[img][/img]
Browser
| posted on 5/12/04 at 11:06 AM |
I volunteer to let you use my Zetec as a test-bed engine for your manifolds! (with me getting the final 'definitive' versionfree of charge
of course )
Rob Lane
| posted on 5/12/04 at 11:23 AM |
Paul,
Would suggest two small 30mm long threaded tubes welded to outer two inlet runners facing up to fuel rail.
Two matching 'collars' on fuel rail through which go long thread rods/bolts.
These would pull down the fuel rail injectors into their seating slightly better than the single central brace.
Rob
paul_mcq
| posted on 5/12/04 at 01:22 PM |
great info guys cheers.
paul_mcq
| posted on 5/12/04 at 03:08 PM |
looking on ebay and just wondering wat is the biggest size of throttle body that a zetec can take. i seen ones rangeing from 45mm to 78mm wat size
would be the best?????????????????????????????????????????????????????????????????????
Mikey G
| posted on 5/12/04 at 03:51 PM |
Looking at the pictures i see that the inlet tracts are coming straight out of the centre of the plenum chamber. May i suggest offsetting these to one
side of the plenum to create a vortex in the plenum chamber which should increase its efficency higher up the revrange.
Mike
paul_mcq
| posted on 5/12/04 at 04:21 PM |
cheers for all the help i need it all in the final designing and making but heres a pic of the design now which will prob be used as a base for the
final. cheers lads
  xfer
