mackei23b
posted on 11/7/15 at 12:49 PM |
Leaking Clutch Slave Cylinder
Hi there
It looks like I've just blown my slave cylinder straight away.....
I've got a Duratec with Raceline Bellhousing, 0.7 master cylinder, modeo V6 slave, ST150 flywheel with ST150 cover plate and Pinto drive plate
(The clutch is an uprated helix version).
The clutch feel was stiff until I started losing fluid....
Has anyone used the Raceline bellousing on a Duratec, if so what set up did you have?
At present all I can think of is the salve cylinder has over extended, any advice appreciated.....
Ian
rodgling
posted on 11/7/15 at 06:12 PM |
Wilwood master cylinder?
posted on 11/7/15 at 07:00 PM |
Pull back the rubber on the master cylinder.
If it is a Wilwood 0.7" bore cylinder you are probably better off buying a genuine Lucas TRW Girling item, as fitted to Series Land-Rovers see
http://www.paddockspares.com/parts-and-accessories/land-rover-series-2-and-3/clutch.html?p=3
mackei23b
posted on 12/7/15 at 04:03 PM |
Master cylinder looks OK , I'm leaking fluid out the bottom of the bellhousing.
Should have mentioned this in my first post.
Ian
